poorboy1964
I'm not sure what part this is referring to any ideas?
High Pressure Oil Standpipe Service:
On engine built before 9-29-03, if the standpipe running up through the head(s) to the high pressure oil tube is remove, it will need to be replaced. On engines built on or after 9-29-03 the o-ring on the standpipe can be replaced and the pipe reused. Broadcast Message 1426.
