06 F350 6.0/5r110/4x4
So i swapped my transmission out and now it won't crank, Acts like its in gear. I swapped all the sensors from the old trans to the new trans to be sure they're good, they're all hooked up except the main trans plug, its in but the old trans had a spot to put a bolt through it to hold the plug in, my new trans doesn't. So is there a way to adjust the shift linkage or something or could it be due to the plug somehow?
Thanks guys.
Thanks guys.
