help with tuning problems..
mcdaniel1991
Germany
When i make a WOT pass while my truck is tuned with the SRL tune it cuts out a little. so i did some data logging and at times during WOT ICP desired was 14ish and ICP actual was 12ish. So i returned the truck to stock and did it again and altho it was slowwww my ICP values stayed very close(the numbers rose to 26 but they were very close to each other the whole time). I didn't have this problem when i was running the xtream race tune.
Im also have another issue that only happens while my truck is tuned. After a WOT pass my turbo seems to stop working for about 10-15 sec. I get only like 2psi and the truck smokes like crazy, then it all goes back to normal. I have this issue with any tune I have tried so far...Innovative and gear heads.
