How bad is it?
high desert stroke
Trailer Park
So....long story short. Wife has been driving my truck. Calls me at work and says truck died. I get there and its a no start, no code condition. Automatically I swap out the CPS. But then I check oil level before firing it up. Its 7 quarts low! Find out that my high pressure oil crossover has been leaking. Fix all that, fill it up with oil and it starts and runs fine. However....now it cranks for
3x as long before it fires. What got smoked? IPR? HPOP? Any advice is greatly appreciated. Thank you guys!
late 99 F250 with 225K miles. Original everything, injectors, hpop, etc...
Justin@DP-Tuner
Probably just air in the lines... You should know within a couple hundred miles. If it doesn't return to normal, there is some other issue.
rsater1
FLA
get on it... WOT runs.... 5 to 10 good WOT runs should do it ..or wait for 200 hundred MILES...!!!!
