Power Strokes
7.3 Tech
how do I find out what injectors are in my truck? or if it has them?
[QUOTE="superpsd, post: 1357474, member: 15821"] You could get it live tuned but its going to cost a bit. Or get some data logging and go back and forth with a tuner. As for not knowing what injectors you could pop a valve cover off and at least see what the solenoid code is but that will likely tell you nothing as you can put any solenoid from any code on the injectors. I think some builders serial stamp the side of the injector that will be exposed when you pull the valve cover with some luck you may be able to track them down. Are the injectors quiet or loud? single shot injectors which is most performance injectors will be louder than split shot injectors which your 99.5 would have came with. So you may have single shot injectors running on split shot tunes if the tunes are for a stock injector truck. If you don't know the difference go listen to an older obs and then a SD with stock injectors. Typically there is a huge difference in sound. [/QUOTE]
B
7.3 lift
Latest: Bmcgarvie
Today at 11:48 AM
7.3 Aftermarket
6.4L Ring End Gap
Latest: ncollins64
Thursday at 7:02 PM
6.4 Aftermarket
7.3 fan clutch noise
Latest: OBS-Addiction97
Thursday at 5:01 AM
6.0 Aftermarket
6
Why do 6.4 rocker arms wear out and 6.0s dont?
Latest: 6.0FinnaBlow
Wednesday at 9:00 PM
6.4 Tech
T
Mini Max Tuning
Latest: tom6mn
Wednesday at 4:23 PM
6.7 Tuning
Power Strokes
7.3 Tech
