Power Strokes
94-97 Aftermarket
How much is safe??
[QUOTE="Charles, post: 85562, member: 103"] Fwiw, I am changing out the rear diff lube today because it is destroyed. The fluid is scorched dark and smells like hell. This is in a Dana [b]135[/b] with 4.88 gears. The ZF6 pops out of 4th gear on a routine basis now as well. Point being, with a well tuned 7.3L powerstroke exhaust gas temperature will be the least of your concerns, as a well tuned 7.3 will see the complete destruction of the drivetrain behind it when push comes to shove. If you're engine is regularly exceeding 1250 degrees at WOT and you're not having any drivetrain problems due to severe loads being pulled, then the engine is simply not well tuned or it's ill-equipped for towing duty and you should reassess your turbocharger and nozzle selections. [/QUOTE]
Lower coil spring pad bolt
Latest: KBMKVIII
Yesterday at 8:09 PM
C
SXE 363/68/.83 + 200/30 hybrids?
Latest: cjfarm111
Yesterday at 12:16 PM
7.3 Aftermarket
H
Howdy
Latest: hillarysmith720
Yesterday at 12:26 AM
Newly Enlisted
Latest: Powerstroke Cowboy
Tuesday at 8:39 AM
7.3 Aftermarket
Best aftermarket stock-ish headlights?
Monday at 7:34 PM
94-97 Aftermarket
DEEZUZ
Power Strokes
94-97 Aftermarket
How much is safe??
