smokinstroker92
Currently I have a cooling mist setup with two 250psi pumps each feeding a CM12 nozzle, which according to the website flows ~14gph. That theoretically should give me a total flow of ~28gph at full flow. System is setup with a progressive controller with the first stage beginning flow at 12psi of boost and ramps flow until 28psi where the second stage comes on at full flow. The first stage injects preintercooler about 6in from inlet and the second stage injects post intercooler about 12in from y pipe.
With my current setup 400/400s, big turbo, headers, cam, headwork, ect. The water injection won't even touch the egts with the current 2 nozzle setup at wot.
After talking with cooling mist I was told each pump would supply a CM12 (~14gph) and a CM7(~10gph). If I add another CM7 nozzle to each stage giving me two CM12s and two CM7s giving me theoretically a total flow of ~48gph at full flow.
My question is would this be to much water to inject without risking engine damage? This would only be used for competition use (sled pulling and drag racing). I'm sure it would be better to add more water slower say adding one nozzle per stage or starting with smaller nozzles but at nearly $40 a pop I don't want a bunch of extra nozzles laying around.
