Justin@DP-Tuner
- Joined
- Jun 22, 2011
- Messages
- 2,170
- Reaction score
- 0
Nice write up, I would add if you didn't want a soft code for the AIH, you should install at least 1Watt worth of 470 Ohm resistors grounded out.
Thanks. And yes, you could do that for piece of mind.
Nice write up...
If you could add the necessary info about the resistor I would be happy to put that in the library. I think I have seen trucks not run a contribution when the heater was deleted but the resistor was not in place. PM if I forget.
Does this affect the cold starting in the winter thanks Bobby
Cool, I've been thinking of installing some resistors after this delete.
Thanks!
