+1 on FICM. Keep your foot off the skinny, but im sure you already knew that. I can consistently get 17 MPG in town, and around 20-21 on the freeway. Im running the same tunes as you. Are you running the SRL as your daily driver?
If your truck is loping when its cold, and your fuel PSI wonders with the lope, probably is a stiction issue. I would recommend getting a cycle of Rev-X in, on your next oil change, see if this helps. But would that affect your fuel economy... not sure about that one. Im starting to have a little stiction, and have Rev-X on the workbench ready to go. I havent seen a decline in my fuel economy though.
