White_monster
Hey guys. Had a spare hpfp kickin around so I figured I'd take it apart. Here's a few pics of the internals of the pump. These pics should shed some light on what's inside.
Volume control valve
Pressure control valve and pump piston
Internal shaft of the pump
Gerotor pump and ring
Enjoy guys. The ring around the gerotor pump is flipped for reverse rotation which makes it easy to replace a pump if you run a twin pump kit using a k16 pump.
