rollingthunder
- Joined
- May 26, 2011
- Messages
- 204
- Reaction score
- 0
Have an 05 that died on me at work. I changed the oil Thursday night, drove it for 5 miles then, went to work Friday, around 30 miles. Everything ran fine, no extended cranks on the two start ups. Around noon went to go grab lunch and it just cranks. Fuel pressure is fine ( 62psi) ficm is a swamps 58 that shows a solid 48v on ae. Ipr jumps to 85% icp wont get above 440 psi.
I pulled the ipr and the screen was 50% clogged with small black pieces. Truck is in a parking lot and I don't have any way to apply air to check for leaks. Stand pipes, dummy plugs and stc fittings were done around 50k miles ago when injectors were done.
Leaving towards hpop pump going but wanted some other opinions.
Thanks
Thanks
