hpop reservoir has no/low oil level
itzdalton
my buddys 7.3 that hasnt started in a month or so now. i havent looked at it myself, but he said that it cranks and doesnt start. hpop res is empty. i am thinking the lpop is wore out maybe? it has over 300k miles on it and probably never had a lpop put in it.. is there any other cause to low hpop res oil level other than the lpop?
ghohouston
Lewisville,Texas
Torn injector o rings is the most common suspect
itzdalton
I put all new injector o ring in that truck in march 2012. Not to say one hasnt wore since then, but they wouldn't all go out at the same time and make it not run. He said he started it up, it ran for aboit 10 seconds and then died. Now all it does is crank.
