im trying to do my 6.4 head gaskets and studs cab on anyone have tips
jmd2422
im trying to do head gaskets and stud cab on does anyone have any tips im working on getting the 6 bolts out on the back side of the turbo right now wich is a pain but so far so good hope to get some responses
Dieselcraft
Moore O.K. Tornado alley
^hmm true
Pull the rad,condenser,tranny,cooler
Support front end,fan,stator,fuel filter housing, egr cooler,intake elbow,coolant tube,ccv container air tube inlet,
Turbos,turbo u tube braket,exhaust shield, hp fuel supply lines,hp fuel feed lines,
Valve cvrs,fuel feed lines,fuel manifolds,rockers, injectors, head bolts you can leave up pipes attacched but easer to remove. Advse using cyl head lifting brkt
Turbo up pipe bolts
6 point wrench
1/4 10mm swivel socket Mac flat head air ratchet
Theres some more secrets
Just remember if they start to round stop and post up
vatejf
How'd it go doing it all cab on? I think I am going to be doing this pretty soon myself.
jmd2422
sorry vatejf i have not been on in a while but it went good not as hard as people would think the hardest part was the bolts on the up pipes behind that go to the turbo
