Power Strokes
7.3 Aftermarket
Improper tuning???
[QUOTE="superpsd, post: 1528377, member: 15821"] What is the ICP numbers now hot and cold? I would diagnose this issue to rule out the injectors but there have been many threads where the owner chased and swapped parts left and right to have random issue after issue only to give in and pull the injectors to send them to anotherbuilder to find out they were poorly built. Your paticular injector builder has had a reputation of this. Although they have alao khad thousands of happy customers so take it as it is. I can tell you one thing its a known fact they rebuild their injectors using the shim kits which is a band aid. In fact very few injector builders actually machine the oil side parts back to specifications and or replace the oil side. Pull a valve cover and pull a solenoid off and look to see if they are shimmed... [/QUOTE]
Latest: ncollins64
Monday at 7:08 PM
6.4 Tech
Latest: HeavyAssault
Sunday at 3:43 PM
Sunrise Ford Parts
B
No Start help
Latest: bismic
Sunday at 9:58 AM
Latest: 6.0 Tech
Saturday at 11:12 PM
6.4 Tech
Latest: 03f3507.3
Friday at 2:11 PM
Engine and Drivetrain
Patrick Feeley
redcat84
bismic
tangoparson
Power Strokes
7.3 Aftermarket
Improper tuning???
