Hey Doc,
Isn't the actuating of the spool valves commonly known as inductive heating? I thought the two were the same. I thought that, the 1st flash that was supposed to solve this cycled the spool valves in between injection events and that really heated up the FICM then their 2nd fix had the in- between firing cut off around 150 degrees. If I was mistaken I appologize for bad information. I was just using the information given to me with my FICM Tuner which has an inductive heating and non-heating program. When I run heating the cold injectors will buzz for a few seconds each when I turn the key on and when I run no Inductive heating there is no buzz.
