Injector cup replacement
Myerswelder
Greentown, IN
I'm getting ready to replace my injector cups. I bought the Alliant Power brushes to clean the head up after I take the old ones out. My question is when installing the new ones do I just use red loctite or is there something better? Thank for the help.
pdumont01
CT
Use the green loctite it is made for press fits.
DEEZUZ
NO PUKESTERS
NWI
Are you getting fuel into coolant? What is the reason for replacement
Myerswelder
Greentown, IN
It all started when an o-ring blew apart and caused my motor to injector knock. It dumped so much fuel in my cylinders it hydrolocked it. When I pulled the injector the end was nasty with carbon build up. After looking at the hold downs they had all like came apart. 2 injectors were so stuck it took 2 of us with a pry bar to get them out. The cups are so nasty it'd be easier to replace them than to try and clean them up. This was how bad they were...
