speedinpowerstroke
i am putting in new injectors and was told i have to siphon out the cylinders, or it will hydro lock is this true? or will it just blow out the exhuast?
I just pull the glow plugs, set the valve covers on (or you will make a huge mess)and crank it over doing them at home. If/when I get a shop I will most likely get/make a extractor. It is possible to bend a rod if too much oil enters the cylinder, better to be safe than sorry.
Don't work that way on a 6.0. Glow plugs are not under the valve cover.
I have done hundreds of set and never once had a problem with it.
