Nic
The truck has 156k. Stock sticks. I keep up with the oil and fuel like no tomorrow. THe truck is a grocery getter. Drives on the weekends. Im not throwing any codes, she starts up just fine, no shaking, shimmy, rough idle, no white smoke, no nothing. I ALWAYS let it warm up to at least 120 before it leaves the drive. Here lately, right when I take off, just moderate throttle getting up to speed it sputters like a bad injector. Not bad, but you can tell. I have no idea how one could be bad. I run amsoil with the bypass kit and still change it every 5-7k. I get fuel from one place only and it sees either the ford additive or stanadyne EVERY time. The only other thing I can think of is fuel pressure maybe? I have the AD100 and its working fine, and I know Its just a pusher pump, but could I still have a FP issue that could be causing this?
Ill be putting it on a graph soon, but thought I would still ask in case I was missing something. It seems a little more sluggish than it used to be but the transmission is pretty much shot also.
