Ipkyss
- Joined
- Jul 16, 2011
- Messages
- 1,032
- Reaction score
- 0
So I have been working what was suppose to be my new "fun truck".
Its a 11/03 build 2004 f350 140k. Motor dated 2004 on the right valve cover. I bought the truck under the impression it needed head gaskets, injectors, and some other general stuff. Truck was sitting not touched for almost two years.
After changing the oil, filters, serp belt, checking fluilds, ect. It was running good. Figured I would take it for a ride and see how everything was. Well next day one of my work trucks breaks down at the start of the big snow storm we just had here. This truck ends up pushing snow for over 30 hours flawless. In the last two days I have put 600 miles on it towing around 8-9k through some good hills.
Truck was a gallon low on coolant to start with. Added another half gallon while plowing. Maybe some air pockets. Coolant level has not moved since. I don't think there is any issue with the head gaskets at all.
Now the injectors. When the truck is at running temps. It runs as smooth as can be. Like new. Cold start while plugged in is normal. Cold start (20-25 degrees) is another story. It actually fires up better then any other 6.0 I have, But smokes, shakes, with a good miss on at least 1-2 cylinders. It takes a good 10-15 minutes for the miss to go a way. Long after it goes to high idle.
warranty history only shows a few reflashes, last one in 05 I believe. And the manifolds/ up pipes changed late 07 at 75k. Is it safe to say the injectors are shot or is it just a striction issue that its worth trying some rev x or sea foam with?
