injector- Turbo differences for 2014/2015 6.7
OzzyBrad
Australia
Hi All, my F350 compliance plate says 3/2014 but if you decode the VIN it says its a MY15 model, i am told the MY14 and MY15 have different injectors and turbos for that matter,
How do i tell what i have without pulling apart ? just wanting to preorder parts if needed.
Mesa, AZ
Eyeball the lower intake manifold. If it has 2 pieces that attach to the turbo, you’ve got a 14, if there is only 1 piece that connects to it, in a traditional location, I.e. the compressor inlet leak n the center of the compressor cover, then it’s a 15.
OzzyBrad
Australia
Great thankyou for your help, i will check it out.
OzzyBrad
Australia
Yes it has the exhaust brake button in the cab, the lower intake is made of cast aluminum, it also looks one piece i think as member 6.0 Tech mentioned, with single inlet into turbo via rubber coupler.
Mesa, AZ
That’d be a 15 then
