Interior light problems
Bosque_6.7
San Antonio, Texas
2015 6.7 stock interior and exterior bed bulbs, for some reason my interior lights nor exterior bed light do not turn on when I open any door in my truck. They do work when I manually turn them on at each switch however. I would like to mention that i also have amp steps and they work just fine, I have checked several fuses and sprayed the doors with WD-40 in hopes that would fix the issue but no luck. Any other relays or fuses i should check? thanks for your help
