greenthunder7.3
I have a late 99 f-250 ext cab long bed 4x4 for sale it has 267k miles. trans was supposed to be replaced at 200k I have no paper work to prove it but it shifts great so I have no reason to dought it. just recently replaced starter and positive battery cable set up. I removed the muffler because it was leaking and welded in a piece of pipe. changed brake line going to rear axle. cleaned ipr valve. new blower motor resistor pack. truck runs and drives good. the body is rough the bed wheel wells are rusty and the cab corners and under the doors is rusty. has some little dings and a dent on one bedside. interior is ok. its a little dirty and drivers seat has some wear. has heavy duty rear springs. front tires are like new. rear ones will need to be replaced soon. guy I got it from had 2 new ones put on the front. make a good work truck. asking $5800 obo. located in central il between Bloomington and Peoria it has no tail gate.
