I decided I wanted two 7 inch light bars flanking the ford logo inset into the grille. Eventually, I want to add a 20" bar either in the grille or in the bumper opening and rigid dulleys in the fog lights.
Building the bracket to hold the lights took a little trial and error, but I think it came out good. It wasn't the easiest to make the bracket but only took a few hrs.
Below are a few pictures of the build, figured it might help others.
All comments are welcome, as if there is any interest I might consider building a few of these brackets for others, it would be cleaned up more obviously.
I haven't wired the lights yet but you can see the finished look with grille reinstalled. I've ordered an electronic shift on fly button which will go in the stock location that will be used to control the front light bars.
