Level and component options
NevaEnough
North Carolina
What's up guys. New guy here with a 2.5" lift question. I've searched around during the past few weeks. I'm still not sure if mixing components is a good idea.
I own a 2014 f250 4x4 cc sb. I'd like to put a lift/level with 22" wheels and 35s. What are your thoughts opinions on the equipment I've put together? The budget is under 2gs. I'd like a softer ride that would accommodate the larger wheel with no trimming. I do minimal towing. (Jet ski) here's what I've come up with:
Carli 2.5 coils
Carli Ford commuter shocks (Fox 2.0)
Icon adjustable trac bar
Icon 4" blocks
I haven't decided on wheels and tires yet.
Is there anything else I will need for a better ride or necessary components. Any input or opinions will help. Thanks in advance.
Love this forum been learning a lot.
Jgon08
Depending on offset and back spacing you may have a hard time Fitting 22/35's on just 2.5 without some trimming of some kind.
NevaEnough
North Carolina
2 grand budget for lift only.
Ok so I'll most likely need a bigger lift?
I've read some guys on here that clear with just a level. They must've had a lower backspace.
Well, does that kit make sense?
MadDiesel73
Glen Burnie, Maryland
the trimming needed would be minimal. if any. i wouldn't worry about it. i have a buddy with a 2013 and icon 2.5 running 22x10 - 24 american forces with 35 12.50's and he didnt have to trim anything.
Swampfox
TN
Carli 2.5 coils
Icon 4" blocks
You will need the alignment cams and brackets to drop brake lines. I have 35" Toyo's and 22x11 American Force wheels and the only thing I had to trim was a very small piece off the fender flare and pulled the liners back. You would really have to look hard to find it.
Swampfox
TN
Great, thanks.
So you don't think a steering stabilizer or a 4 link would be necessary with this setup?
I have the Carli high mount steering stabilizer on mine and it seems to help over the small stock one. I'm not sure about the 4-link, never had any experience with those.
NevaEnough
North Carolina
Thanks SwampFox. I've been looking at the PMF Blocks. It has an option to add a 2.5 and a 5.0 taper. What does that help. I honestly want to put a quality lift/level on my truck and am willing to put the dough into it. Just want to make sure I'm doing right. Sorry for all the questions.
