Likelihood of fuel pump failure after replacement?
BigJerm7
Bought a 2012 with 67k on it, now has 72k. Great shape, well taken care of. Pulled OASIS and fuel pump was replaced at 48k under warranty. Said "no signs of contamination". Changed fuel filters and found the tiny metal shavings in frame mounted cover. I'm hoping they are residual from the original failure. I use lubricity additive with every tank. What is the likelihood the fuel pump will fail again?
