Power Strokes
7.3 Aftermarket
Livewire Ts Programmer
[QUOTE="dustinz85, post: 442978, member: 3649"] From SCT Facebook page For those that requested a PID list, here is the current PID list the Livewire TS is shipping with. As you can see, we spent a little time adding as many as possible: 6.0L & 7.3L Ford Diesel ACCEL PEDAL POSITION AIR FLOW #/MIN BAROMETRIC PRESSURE IN HG BATTERY VOLTAGE COMMANDED GEAR COOLANT TEMP ENGINE OIL TEMP F INJECTION CONTROL PRESSURE INJECTOR PULSE WIDTH INTAKE AIR TEMP LOAD TURBO BOOST MAP RPM TORQUE CONVERTER CLUTCH DUTY CYCLE TRANS TEMP VEHICLE SPEED VGT DUTY CYCLE FICM_IGNITION FICM_LOGIC_POWER FICM_MAIN_INTERNAL_INJECTOR_PWR 6.4L Ford Diesel BAROMETRIC PRESSURE KPA BATTERY VOLTAGE COOLANT TEMP DPF REGEN STATUS EGT ENGINE LOAD ENGINE OIL TEMP INTAKE AIR TEMP MAF PEDAL POSITION RPM SECONDARY EGT TRANS TEMP TCM TURBO BOOST VEHICLE SPEED 6.7L Ford Diesel ABSOLUTE LOAD IN PERCENT ACCEL PEDAL POSITION D ACCEL PEDAL POSITION E ACCEL PEDAL POSITION VOLTS AMBIENT AIR TEMP C AMBIENT AIR TEMP F AVERAGE DISTANCE BETWEEN REGEN BAROMETRIC PRESSURE BATTERY VOLTAGE DISTANCE SINCE DTC CLEARED KM DISTANCE SINCE DTC CLEARED MILE DISTANCE SINCE LAST REGEN DPF SOOT MASS DTC COUNT DTC COUNT TCM ENGINE COOLANT TEMP C ENGINE COOLANT TEMP F ENGINE OIL TEMP FUEL LEVEL SENSOR FUEL RATE GEAR COMMANDED INTAKE AIR TEMP VOLTS MAF FREQUENCY MAP ABSOLUTE KPA REDUCTANT LINE PRESSURE REDUCTANT UREA LEVEL RPM RUN TIME TCC SOLENOID PRESSURE KPA TCM TRANS FLUID TEMP F TCM TURBO BOOST VEHICLE SPEED MPH TCM [/QUOTE]
Latest: ncollins64
Monday at 7:08 PM
6.4 Tech
Latest: HeavyAssault
Sunday at 3:43 PM
Sunrise Ford Parts
B
No Start help
Latest: bismic
Sunday at 9:58 AM
Latest: 6.0 Tech
Saturday at 11:12 PM
6.4 Tech
Latest: 03f3507.3
Friday at 2:11 PM
Engine and Drivetrain
Power Strokes
7.3 Aftermarket
