roachie
- Joined
- Sep 5, 2011
- Messages
- 123
- Reaction score
- 0
I'm kinda leaning toward a failing SCT fitting, Stevo says its the Hpop.
Hot or cold it has a 20-30 second crank time.
Letting it sit non running more than 15 minutes, long crank time for you.
Driving down the road, pressure is fine.
Air test on the system with IPR valve closes was not really revealing anything. I could hear a faint noise with a stethoscope near the rear lower portion of the engine.
I think it has the updated branch tubes (they have a spring and ball in them)
Scanner shows nothing out of the ordinary.
ideas?
ideas?
