Power Strokes
7.3 Tech
Long crank hot or cold
[QUOTE="Slats, post: 1545251, member: 32685"] I’m not sure what to try anymore. I have been chasing a long crank to start hot or cold. I live in Vegas so it’s not like the air temp is to cold to need the glow plugs to be a necessity to start. The Hpop res has been empty in the am. I have filled it and it still took a long time to start. I have Changed the oil n filter Hpop to res gasket LPOP Replaced the Hpop reservoir thinking that it had a crack The truck has 500,000 miles on it. It runs great. And smooth. The fuel filter is not oil contaminated I changed the lpop to rule out the week pump filling the Hpop res About the only thing left to check is the ipr for a sticky valve or bad o-ring. I really don’t know where the oil drains from. I’m hoping that you guys can give me some help. Thanks in advance. [/QUOTE]
10R140 failure
Latest: PSD-BLACK-CLOUD
Friday at 1:04 PM
2017+ 6.7 Aluminum Super Duty
2010 headunit
Latest: glog
Wednesday at 1:17 PM
6.4 Tech
D
Latest: donaldtfreeman
Tuesday at 10:43 AM
6.0 Tech & FAQ
Latest: Tiha
Tuesday at 8:07 AM
7.3 Tech & FAQ
Latest: ju015dd
May 4, 2025
6.0 Aftermarket
Power Strokes
7.3 Tech
