Power Strokes
long crank time???
[QUOTE="Triumph1188, post: 973287, member: 13562"] Otherwise you can splice into the ICP sensor on the passenger side valve cover and monitor the voltage while a friend turns the truck over. The computer won't fire the injectors if a minimum voltage isn't met. I belive .8v? Have you checked the voltage at the ficm? That could be going out. Are any updated parts installed in the high pressure oil system? Stc fitting, dummy plugs, stand pipes all have updated parts to eliminate leaks that cause a pressure drop. The stc fitting will blow off in some cases and take out the rear cover if it gets bad enough. [/QUOTE]
Latest: ncollins64
Monday at 7:08 PM
6.4 Tech
Latest: HeavyAssault
Sunday at 3:43 PM
Sunrise Ford Parts
B
No Start help
Latest: bismic
Sunday at 9:58 AM
Latest: 6.0 Tech
Saturday at 11:12 PM
6.4 Tech
Latest: 03f3507.3
Friday at 2:11 PM
Engine and Drivetrain
thomasmasons214
Derkperk
dsberman94
Sterling6.7
kbsd
drtyhands
tangoparson
Power Strokes
long crank time???
