Vader's Fury
I have an 03 F-450 that I am working on for a buddy. He is having a wierd issue where the Water in Fuel light is coming on and the truck is loosing power. Kinda like going into limp mode.
I have changed out the sensor, drained the tank, cleaned it out, and replaced the fuel. Removed the fuel filter housing from the frame rail and cleaned it out. Truck is still doing the same thing.
I even tried unplugging the sensor and running the truck like that and I am still getting the same issue. Light will shut back off after a random period of time and truck will run fine until the light comes back on.
Any Idea's/Things to check?
