Loss of coolant
Twan
Berthoud, Co
I had ARP's new head gaskets installed a year ago, heads where checked and flat, ARP's were installed per ARP's specs. It just started pushing coolant again, but only under full load with trailer and above 25psi boost.
I put a new cap on and it did fine for 1,000 miles before acting up again. My deltas are within 8* pulling. Motor never got hot, put a pressure gauge on the coolant line, but it's under the hood, I seen it as high as 14psi when I stopped to look at it.
Could I have already blown a head gasket again?
Twan
Berthoud, Co
Was all cleaned, got lucky that everything was flat.
When I did the studs my gaskets were still good too.
I need to get a coolant tester to see if it is getting exhaust gas in the coolant.
Twan
Berthoud, Co
My bad, read that wrong.
They used the brass tools. Made sure it was flat, and smooth. Put the heads in a cleaner and used brass to finish them.
loboost
That reads the exhuast right?
Yes. It'll turn one color or the other if exhaust gasses are present in the coolant.
You say the new cap fixed it for 1k miles or so?
sent while driving recklessly
Twan
Berthoud, Co
Yes it did, it's also a auto zone cap, only place open.
I'm going to the ford dealer tomorrow in Decatur, Tx to see if they can test my caps, and get a new one. Got to haul trailers home tomorrow.
DEEZUZ
NO PUKESTERS
NWI
New caps will last about a month with bad head gaskets. It wears them out quick. They advertise pip off at 16 but I've tested some ford ones to 18 psi.. They'll only hold so long.. If your seeing those pressures yiu either have a coolant flow restriction or headgaskets, if your egr is gone.
Twan
Berthoud, Co
I put a pressure gauge on and have yet to see it over 14, I believe. Normal was 10, even after it leaked.
What should be a normal pressure?
DEEZUZ
NO PUKESTERS
NWI
Well test the cap, it might be blowing off at 14 and you won't see any higher... As for normal I can't say, everything I've tested was bad. From what I can gather, normal pressure is anything under cap blow off and as long as the pressure fluctuates.
Twan
Berthoud, Co
Thanks man.
I'm hoping it not a head gasket or craked head.
Does ford have a way to test my coolant to see if it has exhaust gas in it?
Or anyone in the Decatur, Tx area?
Trqmnstr
VT
I thought i was still blowing coolant after delete, studs and gaskets. Was getting the same spray on the Degas bottle i was having before the work. Turned out the return hose to the bottles wasn't clamped good.
If your seeing spray thats looks like its from the cap that may be it anyways.
rray37375
Sewanee, TN
I had problems with coolant loss, turned out the degas bottle was cracked on the bottom, you couldn't see it from the top, and it wouldn't leak unless it was under pressure. New bottle and cap less than $100, problem solved.
Twan
Berthoud, Co
I will get a new bottle ordered up, can't hurt. I will check my hoses this morning. Thanks guys.
Last night I put a presser tester on the coolant system, at 16psi my upper radiator hose started to leak, and spit coolant. Reset the hose and system held 16 psi for about a hour
