JAP
Air pocket. That makes me laugh. Where does this magical air pocket come from? When you have liquid in a sealed system air doesn't just happen. It would have to get I the sealed system through a hole in the sytem. or picked up by either end of the sealed system, meaning your tank would have to be empty. If air was getting in somewhere else then that would mean a hole in the sealed system an thus fuel would be leaking. I would think people would notice a leak.
Anyone have a clue how a piston pump work?
So is rusted injectors caused by low fuel pressure?
Never once did I ask the question if lower fuel pressure will cause power loss. I know that answer. I asked if low fuel pressure will damage injectors. I also don't disagree that Ford says it does, but that doesn't make it fact. It just means they have another excuse to not warranty injectors when they have a problem. Ford also says that you can't remove the spacer from the back of the crank. It is in all the manuals, yet I have done it several times many years ago with no ill effects and I know many others who have also. I have also converted 2wd trannys to 4wd with only a simple part swap and never removing one single part from the inside of the tranny. Yet everyone seems to still says that is impossible. Not to mention how many 6.4 trucks I have running around the country with a duramax cp3 pump on them that everyone says doesn't work.
I'm not sure if this has been started over here, but I just want to know if anyone has any insight?
To me, it SEEMS obvious... But I'd like to know why Lubeowner thinks that low fuel pressure is OK?
Cavitation and liquid dynamics seem to say that cavitation can happen at any time during a major pressure differential...
Lubeowner goes on to say "Where does this magical air pocket come from?"
Umm... Seriously?
I'm just mainly curious if he's fking around on PSN or if he really doesn't understand?
