Farmrod
05 6.0 with 41000 miles was running good then all of a sudden won't run would start and sputter then die now just cranks hooked up scanner voltage was low replaced batteries voltage is back where it should be ficm voltage stays at 48-49 volts icp is 1475 while cranking what else should I check.. fuel pump is running I plan to change filters in the morning any help would be greatly appreciated
Chris
Chris
