caladash
06 King Ranch 2wd drive. Buddy needed a hand getting it running. Dropped it off on a gooseneck! Scanned for codes and had a low ICP code cleared it and no start. Unplugged ICP sensor and still no start. Monitored ICP while cranking and got 5 psi. FICM sync and voltage are all good. Pulled off the oil cap and found a fram filter in there. Kept the cap off while cranking and it fills with oil then drops right down. Put the filter in and pressed it down while cranking and it does the same thing. Is the bypass valve in there the issue? If so how do i fix it? Also oil gauge on the dash does not move. So far fuel side checks good.
