Have a buddy that has a 2001 7.3 with 262k, we have replaced orings on the injectors, t500 hpop, icp, and ipr. Once it gets above 80 degrees oil temp it will not restart. If I bring it all the way to operating temp it will only build 4-5 psi hpop with ipr at 65% when trying to restart. When running it has low power at operating temp but still runs until it is shut off. Operating oil temp is 196 degrees, the hpop revisor is also 3/4 in from the top and it is full of oil. We have switch from 5w40 to 15w40 and the thicker oil did help with cold starts. Any help/ suggestions are welcome.
