Making weird noises
FL
X2 on U joints. Park on level ground, put the trans in neutral and move the drive shaft back and fourth. If you have a bad U joint you should be able to tell easily.
Pstrke96
Dunnellon fl 34433
^^^^ not always I had a bad joint in my SD last year and after I twisted and jerked and yanked for about 3 days with no significant movement I brought it to a shop and the rear most joint was bad. However the symptoms you describe were the same as mine.
