Misc. Parts
NyCowboy87
Arkport, N.Y.
My truck is getting gutted to be a dedicated puller, everything is coming out. Interior, wiring harness, dash, hvac components, etc. If there is anything you need let me know, everything is in good working condition and is coming out of a 95 f250 extended cab xlt model.
davey99ps
Waterford WI
How's the dash pad? Any steering column parts? I'd also be interested in the gray trim that runs across the middle of the dash, 1 peice on either side of the steering column an then 1 peice that runs under the radio all the way to the passenger side above the glove box
NyCowboy87
Arkport, N.Y.
Dash pad is cracked like usual, not horrible but not great. I know I have the trim pieces let me make sure the clips are not broken off them. I can snap some pictures tomorrow for you if you would like. I do have steering colum parts as well.
davey99ps
Waterford WI
I really only need the 2 trim prices around the column, actually just the 1 on the right side of the column. I'm not sure the peice I need for my steering column, my shift lever has some slop to it. Idk if you still got my #, otherwise I can pm it to you. My dash pad only has a small crack, was hoping for a clean 1.
NyCowboy87
Arkport, N.Y.
Sorry I havnt gotten back to ya, the dash pad is cracked pretty bad like I said and the trim pieces are black on my dash for some reason. As far as the slop in the shifter, there are plastic bushings in there. I would just go to ford and get them.
