Mistake? Black Onyx
mikelee
Well I have Recently purchased ARP studs and Victor black onyx head gaskets. Figured I had done enough research on them but maybe I haven't.....
Read a couple of places where people say the Black Onyx gaskets are equal to or better than OEM. The victor gaskets are also multi-layered. Then ive heard horror stories. Most of the post ive read were from 2011 or older.
Any chance the gaskets have been improved? Why would performance companies even sell them if theres a high failure rate?
My cylinder heads have been machined and everything checked out ok. Machined, hot tanked, checked for cracks, valves vacuum tested.
Derkperk
Twin cities
There was nothing wrong with the stock gaskets design so most guys used them, as did I. I believe the BO gaskets are cheaper. I too have read plenty of stories but remember, most everyone will bich when they have a failure.
I'd guess since you have done the proper head and deck prep, you'll be OK.
Oroville, CA
Depends on which gaskets they are. If they look just like the Ford gaskets but with black instead of blue they are fine. If they whole gasket has a black coating, then it's the only style that people have problems with.
I also recommend you get the heads o-ringed as well.
mikelee
ok ill have to check them when they come in. Hopefully they are like the ford but black. Also yes im a huge believer that surface prep is everything. I spent most the day cleaning the engine deck and ill go over it again just before I install the heads.
Extended Power
I ran them for a year with a single turbo, and A-1 studs.
When I installed compounds....they lasted 3 days.
Switched to factory Ford gaskets, and have changed turbo sizes more than my underwear, and the headgaskets are still holding after 2+years.
ford_muscle1
Fort Lee, VA
The ones in my truck currently are the black ones that look like the ford ones and I have not had any issues. I put them in a year and a half ago and put 30,000 miles on them with no issues.
Once again goes back to people will talk crap about what fails so opinions get biased. I at one point was going to ditch ford and buy a cummins but then I saw the problems my buddies had with their cummins and duramax's and said nope I'll keep the ford.
Extended Power
If you aimed this at me, I can tell you...the BO are crap.
There a reason they are dirt cheap.
Seems every time I try to save a bit of money, it bites me in the ass every damn time.
Like I said, I had them in for whatever amount of time, and they held....but when I switched to compound turbos, they only lasted three days.
I switched back to factory ford, and have had a 66 over 80, 63 over 80, 63 over 82, 63 over 84, 66 over 84, and now a 66 over 94....head gaskets still holding.
mikelee
Well I installed the black onyx. Looked like the Ford ones only black instead of blue.
I'll be running a barder stage 2 turbo with 175 30% injectors so we will see. Hope for the best
