MPD 6.4L Regulated Return w/ Fuel Bowl Delete
Buddy@MPD
Glen Burnie, MD
Now available for sale is the MPD 6.4L Regualted Return Fuel System w/ Fuel Bowl Delete. This kit includes fittings, lines, and regulator that are used to remove the factory fuel bowl on the top side of your 6.4L Engine. Retail for the kit is $599.99 but it will be on sale for $549.99 until the end of April. Check it out on our website http://marylandperfdiesel.com/i-12481739-mpd-fuel-regulated-return-system.html
Crack85
Midland, Tx
what does this do what the reason if its good for the motor im going to buy this for my build
Removes fuel bowl, so whatever lift pump u choose feeds directly to hpfp. Not a necessity but does clean up engine bay
Sent from my Nexus 7 using Tapatalk 2
StrokiNDieseL
Geneva, Fl.
6.4L MPD fuel bowl, Bought kit used & was wondering if kit can be plumbed into fuel cooler for a street truck? My installer says It runs right to tank which will add heat not recommended for a DD? Any thoughts from you experienced gurus?
