White_monster
Ya. There built by RCD. I already inquired about those and Mick told me they were from RCD. Have fun man.
all it was meant to hold was 60's. tadd always said that was the max amount of nozzle it was built for. 2 years after it was released, now technology has changed, but you havent backed up anything with that 947 you made on stock pump and nozzles, so its hard to say against it working. as for lines breaking, i broke one, but it has been common knowledge for a long time you need some sort of support for the lines. you both know that, so if yu broke the lines more than once, thats your own fault. II pump requires the braces as well.
jeff- what does 35% over mean? how long have you had those nozzles in ?
In regards to the fuel line issue, I believe the culprit to the problem is the modified fuel pump. You can see a massive pressure spike when you let off from wot. A stock pump or pumps will not do that.
Went 12.65@105 on 35 trail grapplers and 12.46 tonight with water/meth
3:73's ? and why the hell you spraying meth ?
His truck has 3.55's with 35's.
yeah he mentioned 35's.....
Figured I would elaborate on the combo since it ain't a real good one for racing.
trying something new dont really like it...it actually raised my egts 200 degress lol
