thewrubelator
I'm not sure where it's coming from, I think it might be a crack in the radiator somewhere. Whenever I top off the coolant, the truck pisses out coolant from between the radiator and the fan shroud, somewhere in there, until the coolant level reaches around 1.5" below the full mark, then the leak stops. All coolant lines are tight from what I can get, water pump was replaced with BPD Pump 4k ago, EGR is deleted and studded. Any ideas? Who sells a reasonably priced aluminum radiator that isn't going to break the bank?
