6speedsd
Have the truck torn down for studs/gaskets. It's an early 05 build date (18mm). Bought a set of late 05 build heads (20mm) to put on. Just noticed my early rocker boxes won't work. New heads take the two bigger bolts up top to bolt it down. I thought that change took affect after like 2006 models? Or is it that way with ALL 20mm heads?
My current injector hold downs were T40, but they will screw into the new heads. Were the T45 hold downs bigger? Trying to figure out what I gotta have to make this work, and in a bit of a hurry to get it going. Will my early 05 oil rails bolt up to the later 05 rocker box or will I have to source some new friggen oil rails too? Or did I get sold 06-07 heads instead of late 05's like I was told?
