Need an Oasis Report
impact diesel
stafford
I need to get an oasis report ran on a truck that a friend of mine is looking to buy.
here is the vin:
1FTNW21P84EA36541
OASIS RESULT: 1FTNW21P84EA36541
USA: EN-US
08-FEBRUARY-2012 / 05:55:53 / FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2004 F-SERIES BODY STYLE: F-250 CREW CAB 4X4 ENGINE: 6.0L DIESEL DI V8
TRANSMISSION: TORQSHIFT AXLE CODE: C1 ENGINE CALIBRATION
PAINT COLOR: DARK SHADOW GRAY PAINT CODE: CX RADIO: AM/FM STRO/CD CHANGER/CLK
AXLE RATIO: 3.73 FINAL DRIVE RATIO WHEEL SIZE: 7.0 X 16" FORGED ALUM WHL FRONT TIRE: LT265/75R-16E A-T BSW
GROSS VEHICLE WEIGHT: 8800 LB. GVW
NO WARNING MESSAGES FOUND FOR THIS VIN
ACCURATE REPAIR NOTIFICATIONS
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
DON'T REPLACE A FICM ASSEMBLY WITHOUT FIRST REFERENCING 10-12-06
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
TO ENSURE OPTIMUM COOLING SYSTEM PERFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
New Vehicle Base Warranty
WARRANTY START DATE: 07-FEBRUARY-2004 BUILD DATE: 14-AUGUST-2003 SALE MILEAGE: 00018
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
Click Here for Full Warranty History
| On-line 1878
END OF OASIS REPORT FOR 1FTNW21P84EA36541
© Copyright 2002-2012 Ford Motor Company. All rights reserved.
impact diesel
stafford
Claim Key
Repair Date
Detailed Vehicle Specification
VIN
1FTNW21P84EA36541
Vehicle Line
T/F7
Market Derived Code
F
Body Cab
T/BC
Ver. Series
T/BD
Drive Type
T/E
PLT CD
A1
TRS CD
T/BE
ENG CD
T/YB
Production Date
14-AUG-03
Warranty Start Date
07-FEB-04
Selling Dealer
147097
Selling Country
USA
AWS Claim Key
Time In Service
Labor Hours
Dealership
DIST (Miles)
Repair Date
Prefix
Base
Suffix
Doc
Details
160583
HUBLER FORD LINCOLN
10
21-NOV-03
RECAL
08382501
Customer Comments
CUSTOMER STATES HAS RECALL 03T02
Tech Comments
RECALL REPROGRAMMED PCM FICM, AND TCM PER RECALL
Details
1047927
4
HUBLER FORD LINCOLN
3726
28-MAY-04
RECAL
08725302
Customer Comments
CUSTOMER STATES TURBO HAS DELAYED ENGAGEMENT
Tech Comments
COULD NOT DUPLICATE CONDITION TEST DROVE CHECKED OVER AIR FILTER MINDER SHOWING RESTRICTION RESET MINDER QT KOEO PASS KOEC PO278 CYL6 BALANC
Details
8721460
24
.3
DON MEYER FORD, INC.
28702
12-JAN-06
106782C
Customer Comments
CUSTOMER ASSURANCE TEST DRIVE
Tech Comments
TEST DROVE FOR CONCERN ASSURANCE TEST DRIVE
Details
8746777
26
.7
29016
07-MAR-06
108430A
Customer Comments
RECALL 06E17
Tech Comments
PERFORM RECALL 06E17
Details
9135110
27
1.7
32692
10-APR-06
19D786
109353A
Customer Comments
CHECK CONCERN AC NOT COOLING
Tech Comments
CHECK AC BLOWES AIR HOOK UP EVAC SYSTEM CHECK COMPRESSOR COMPRESSOR PULLEY FELL OFF REINSTALL PULLEYCHARGE SYSTEM COOLING FINE NOW
Details
9808093
30
3.4
34100
05-JUL-06
3C3Z
9F838
EA
111798A
Customer Comments
ENGINE LEAKS OIL HAS NOTICED A FEW DRIPS OVERNIGHT LOOKS LIKE DRIPPING OFF REAR MAIN AREA.
Tech Comments
OIL LEAK TEST, ICP SENSOR LEAKING & RUINED WIRING INTO HARNESS, REPLACED ICP SENSOR, REPAIRED WIRING& CONNECTOR. MT TIME FOR WIRING REPAIR.
Details
10610886
34
5.4
47042
26-OCT-06
3C3Z
6700
BA
114929A
Customer Comments
STILL LEAKS OIL. INSTALLED DYE LAST TIME TRUCK WAS HERE. SEE HISTORY.
Tech Comments
VERIFY CONCERN. BLACK LIGHT TEST FOUND BAD FRONT CRANKSHAFT SEAL LEAKING. ALSO FOUND HOT SIDE CAC HOSE LEAKING. REPLACED CRANKSHAFT SEAL AND REMOVED AND REINSTALLED HOT SIDE CAC HOSE TO CLEAN UP . RETEST OK.
Details
12406717
49
2.1
78370
18-JAN-08
9E527
126764A
Customer Comments
CHECK CONCERN VERYHARD TO START COLD WHEN DIR GET STARTED IT BLEW BLACK SMOKE BAD
Tech Comments
STARTED FINE FIRST DAY MISSED OUT ON START UP REPROGRAM PCM PER TSB 07 05 04 MISS GONE NEXT MORNING STILL RUNNING A LITTLE ROUGH RELEARN VGT FOR TURBOFLUDDER RECHECK ALL OK NORMAL
