RattlinFord
Anyone who's read my other post knows that I'm trying to weed out a shifting issue with my early 99 F250. It's shifting hard into 4th under load and the TCC is working in reverse, seemingly. When you give it about 1/2-3/4 throttle, the TCC locks in...when you back out of the throttle to go to "cruising speed", the TCC unlocks. So that catches y'all up.
Talking to people, and checking things, leads me to suspect the APPS. I thought I had a smoking gun...because I hooked a scanner to my truck and at full throttle it only shows 73% throttle and 3.6 volts. Thought for SURE that was my issue.
Enter today...my buddy has a late 99 F250 and works at a Ford dealer as a diesel tech. We hooked the scanner up and there was no dead spots or spikes in the APPS. Then we hooked to his truck which runs/drives great. His truck only read 76% throttle and 3.8v!
So, can anyone give me the real scoop? I've searched until I feel I can't anymore. Do any of these go to 100%? Or are they tuning-limited? He has a TS 6-position chip and his still doesn't show but 76%. I saw an article on adjusting the APPS (making it adjustable)...anyone ever done this?
Or, is this all me just not being use to an early 99 tuning and the transmission just is gonna shift crappy until I'm tuned? It doesn't slip. It shifts smooth as butter and quick when not under load. But under load it's kinda crappy. The TCC issue is there non-stop. Might wire in a manual override for that. Anyone have any advice/info?
