LiftedBlackHD
- Joined
- Mar 31, 2012
- Messages
- 130
- Reaction score
- 0
Atempted to change oil cooler and weld up egr cooler today. However im stuck on the rear turbo bolt. I have an early 04 build that has 2 horizontal bolts in front and the vertical one in back.
Bolt rounded off. Tried a biter bit and still cant get it.
My only thought now is to grind it off.
Can I unbolt the pedestal and remove the entire thing?
I can only see 2 pedestal bolts. They are on the drivers side, on top of tne valley of the engine. Where are the otjer pedestal bolts?
Thank you!
Thank you!
