Need help finding coolant in Germany!
mcdaniel1991
Germany
I'm stationed in Germany and I'm in desperate need of hd elc coolant. I was using zerex but Im out and I'm doing an oil cooler this weekend.
HeavyAssault
Middle, VA
Motor pool all dried up?? LOL Maybe AAFES garage can get a supplier lined up for you.
I'd see about a APO friendly shipper or ask a stateside buddy. Would USPS ship a case of coolant?? That's pretty heavy and costly at the same time.
Lassie
Tenn River Alabama
Water won't destroy it. Get some coolant ordered and replace your drained coolant with straight water. It will be fine for the few weeks(?) it takes to get some coolant.
And on a side note, we have got to find a way to get your base to stock 6.0 stuff one day!
mcdaniel1991
Germany
Yea right lok they will never stock stuff for this truck. I brought thr truck with me here. I have a friend trying to send me zerex but usps tokd him no? So idk what to do im not even protected for winter its a prwtty watery mix right now from adding to much water. I can get g12 here which is VW specification buy idk if I should use it. It's silikon free.
Sent from my GT-I9305 using Tapatalk 4
Lassie
Tenn River Alabama
I would bet there are some Milspec coolants on base that would work for you. Go ahead and get some, we paid for it....just tell em PSA authorized it.
mcdaniel1991
Germany
Lol I can get coolant on base no problem but it's all green stuff. I need to know what g spec to get. Will g12 work ?
Lassie
Tenn River Alabama
If the green is all you can get, you may want to set up to use it. I know you've heard that's a no-no, but if you get rid of your "gold" completely, the green will provide freeze protection and corrosion resistance.
The difference in "green" and orange/yellow coolants is the green uses silicates and other stuff as corrosion inhibitor. It's life is 30K or less also. If the green and gold mix, the acid used as corrosion inhibitor in the gold, will precipitate the silicates from the green, removing its corrosion resistance. And the precipitated silicates will end up in (your filter if you have) or your oil cooler.
If it's the only easy to get coolant, you really have no choice. Just make sure you completely remove ALL previous coolant first and change your coolant at 25 0r 30k.
mcdaniel1991
Germany
Well I can get red g12 off base at a Germany store they also have a clear coolant
From the interwebs This coolant/antifreeze is phosphate free
and also silicate free. When supplied by Volkswagen,
this coolant/antifreeze is known as G12.
Lassie
Tenn River Alabama
The red (like toyota uses) is green dyed red. Just treat it like green. I don't know about the clear. How long will it take you to get what you want?
mcdaniel1991
Germany
Update above.
It depends on if I can get some one to ship it to me. My buddie tried but got denied.
HeavyAssault
Middle, VA
Any issues with UPS/DHL receiving on base? Got a friendly supply person that would give out the unit address for receiving?? I'm willing to help but a case is heavy and expensive.
mcdaniel1991
Germany
Well I'm sure I could had have ups delivered to my house I would just have to pay taxes on it.
mcdaniel1991
Germany
Nope we don't get much special treatment. I will get in contact with ups and I may get in contact with you to help me out. If you mind
