Need help. Loose brake rotor.
Pigman
Katy, TX
Hey guys, I've been getting a bad chirping/squeaking noise from the front end for a while now and within the past week or so it started making a howling noise when I brake at low speeds. The wheel bearing seems fine but I just took off the front left tire and noticed ALOT of back and forth play in the brake rotor. What could be the cause of this and how do I fix it? I replaced the front left hub assembly and all the brake pads and rotors 14 months ago. The brake pads look fine as well. I don't know how to upload videos so if you want the video just PM me and I'll text it to you.
Thanks,
Josh
Pigman
Katy, TX
If your wheel is off your rotor can move a good amount.
How much though? I'm able to move it back and forth a significant amount and I find it odd that it makes the same exact chirping noise I've been hearing.
G Racing
Southeast Texas
What do you mean back and forth? With the wheel off the rotor will move. Are the stud holes out of round? The brake pads and caliper will keep it from moving too much, unless the slide pins are shot or the caliper bracket bolts are loose.
Pigman
Katy, TX
Had one of my friends at work check it out earlier and it turned out to be the wheel bearing. Luckily it's the same one I replaced a year ago so it's under warranty. Thanks for the help guys.
Pigman
Katy, TX
Well I replaced the hub assembly a couple hours ago and it is still squeaking! The brake rotor is still loose and I know that that is what's making the noise so I just need to figure out how to keep the rotor from shaking. Is it possible that when the wheel bearing went bad it also damaged the rotor? The rotor looked fine when I took it off but I'm no brake expert...
powerstroke95
Batesville,IN
When you put your wheel on and tighten the lug nuts, your rotor wont be able to move. The lug nuts are the only thing that holds the rotor in place. As the others have said, pull your slide pins out and see if there are large flat spots on them. If so, that could be causing some play.
Jomax
Arizona
I made the habit to install new slide pins everytime I install pads.... they're pretty cheap.
PDT1081
Bowling Green, OH
If the rotor is loose, there will be metal shavings. The rotor hub will be shiny and the back of your wheel (hub) will be shiny and chewed up.
It is entirely possible that the rotor is warped. First thing I would do is pull the caliper off. Check/lube the slide pins. I use a ceramic based anti-seize. Then, before I put everything back together, I would bend the wear indicators (those metal clips that hold the pads in that are supposed to squeal to warn you of brake wear) as far away from the surface of the rotor as possible. Maybe even cut them off.
mandkole
Northwest
Is it squeaking when the brakes are applied or just rolling? On some rotors, the hub 'plate' section will warp, but Ive not heard of it with big meaty rotors like on trucks. Its possible that the rotor could be clamped up on a turning lathe and checked. Id agree that a rotor change may be in your future.
Pigman
Katy, TX
Thanks for the help guys! When I get time I will check the slide pins. One thing I forgot to mention is that when I turn the brake rotor by hand, it is easy to turn for about 3/4 turn and is very tough to turn that other 1/4. Also the noise happens when it's rolling whether I'm pressing the brakes or not. Usually happens when slowing down at slow speeds.
Pigman
Katy, TX
UPDATE: I replaced the rotor, cleaned and greased the slide pins, torqued everything to the exact specs and it is STILL squeaking! It might be even worse now. I have no idea what to do.
