82racin
- Joined
- Jan 15, 2012
- Messages
- 53
- Reaction score
- 0
going to be replacing a set of cracked heads on a 03 6.0 (build 11/02)
trying to get all the parts ordered, want to make sure im not missing anything.
heres whats in my shopping cart at tousley ford
3C3Z 9229 AA Injector O-Ring Kit
3C3Z 6A642 AA Oil Cooler Kit (Entire Assembly with Cover
3C3Z 6584 AA Valve Cover Gaskets (Upper, Lower, + Grommets)*
3C3Z 9439 AA Intake Manifold Gasket (3C3Z-9433-BE 2 Gaskets + Turbo Hardware + EGR Cooler Gaskets)*
6C3Z 9448 A Exhaust Manifold Gasket
3C3Z 9T517 AG "BLUE SPRING" Fuel Pressure Regulator
W302472 (Ford Hardware PN) 6.4 Banjo Bolts (You will need 2)*
W303659 (Ford Hardware PN) 6.4 Banjo Washers (You will need 4)*
6C3Z 9T515 A Updated Turbo Drain
3C3Z 9T516 A Updated Turbo Feed
will also be getting egr delete, arp studs, and oem headgasket kit
