Need help still no throttle response
andrewsteelerford05
Garrett county, Maryland
Hello my name Andrew Ganoe and I'm still having trouble with my 05 powerstroke. I have no throttle response still after replacing peddle positioning sensor and icp sensor. The truck starts and idles good but when I push on the peddle nothing happens. If anyone knows what the problem is please let me know thanks.
Justin@DP-Tuner
Do you have a scan tool that can watch APP (pedal position) to see if the value changed when you press the throttle?
powerjoke4life
I had that same thing, ended up being an injector even though it was throwing a contribution code. I spent so much time trying to figure it out. Finally I said screw it I'm putting new injectors in and it ran perfect once I put new ones in.
andrewsteelerford05
Well good news everyone I figured out the problem and fixed it. The ebp(exhaust back pressure) sensor went bad and when they go bad they can ground out the pedal. Put a new ebp sensor and has pedal now and runs great.
