Power Strokes
7.3 Tech
Need help with what turbo this is??
[QUOTE="cowboy_dan, post: 91656, member: 258"] Exhaust gasses go in one side, turn the turbine wheel, and exit. The turbine wheel turns the compressor wheel via a shaft, and the compressor wheel pushes air from the inlet to the outlet. Oh, and it helps to have a good oil supply and drain. One thing about using a turbo from another application is that the OEM of the truck/engine is probably not going to tell you anything about it. They don't want to give out that information since it's proprietary. And the turbo manufacturer probably won't tell you anything about it since it was some custom spec to the OEM, and they don't want to make the OEM mad. [/QUOTE]
Latest: ncollins64
Monday at 7:08 PM
6.4 Tech
Latest: HeavyAssault
Sunday at 3:43 PM
Sunrise Ford Parts
B
No Start help
Latest: bismic
Sunday at 9:58 AM
Latest: 6.0 Tech
Saturday at 11:12 PM
6.4 Tech
Latest: 03f3507.3
Friday at 2:11 PM
Engine and Drivetrain
ToMang07
towerrigger
Power Strokes
7.3 Tech
